View unanswered posts | View active topics It is currently Tue Feb 20, 2018 6:10 am
Reply to topic  [ 5 posts ]
 Gen II ZX14R Fairing Removal
Brocks Performance
Smokins' Video
From Brocks Performance
:arrow: http://www.brocksperformance.com/Instructions/ZX14/996434.pdf
The video helped me a bunch when I got my 14R. I was a first time 14 owner and was able to easily install my Brocks Alienhead 2 full exhaust system myself using tips in this video.
I like the exhaust a lot! Shaved off 40 pounds, sounds great and a nice bit of added performance! Thanks for putting the videos up Brocks & Smokin. :clap:
Mon Jan 21, 2013 4:30 pm
Great video! Saved me from breakin tabs! Now just to fix my radiator and put her back together...
Fri Sep 27, 2013 10:28 pm
Does anyone know if you can remove just the lower fairing while its on the bike. Ive taken off the whole fairing before, just trying to save some time. I purchased a RCC Turbo Clutch Cover and was trying to save some time. I want to trim the lower right side fairing to make it easier to remove plate and cool it with a fan at the track.
Thanks !!
Fastest 1/4 mile 9.11@ 148mph
Fastest 60ft 1.42
Fastest Mile 194 MPH
Stock Motor @ 270 lbs fully dressed :)
Schnitz set up and tune
Tue Apr 21, 2015 10:39 am
Ok Guys, I found out how to take off the lower fairing without removing the whole side. It is really simple. You just remove the center piece, then loosen up the mid fairing piece by taking out the bolts, then remove the bottom bolts of the lower fairing. Then just carefully pry it out away from the motor and remove 1 small phillips screw that is located towards the clutch side, then remove 1 allen bolt that holds a metal clip towards the wheel. Then just lift up and gently pull it off the plastic clips. Only took me about 15 minutes, now that I know how it comes off, it will only take about 5-10 minutes. Very easy. Thanks Dave Miller for giving me a heads up !! Saved me lots of time.
Fastest 60ft 1.42
Tue Apr 21, 2015 9:31 pm
Good info, thanks!
Sat Jul 11, 2015 11:33 pm
Users browsing this forum: No registered users and 10 guests
