View unanswered posts | View active topics It is currently Tue Feb 20, 2018 6:16 am
Reply to topic  [ 22 posts ]
 Gen2 plastic on a Gen1... What's needed for the swap?
I'm wanting to swap gen1 plastic for Gen2 stuff.. Can I use gen1 tank? What all is needed?
Wed Dec 16, 2015 10:22 pm
A guy in Jersey did it 2 years ago to his 2009 ZX14. Not sure how is done.
Thu Dec 17, 2015 10:27 pm
Pretty sure the tank will work. If I ever have a chance to test fit I will, but for now I can only say that so far I have not seen a glaring reason why they would not swap or work with the other gen's plastics, etc. Don't think I have ever had both my gen 1 and gen 2 skinned at the same time.. I will certainly test the premise if I ever have them torn down that far side by side. Worth a try... but not my fault if it doesn't work. ;)
Thu Dec 17, 2015 11:05 pm
tank works
if your changing the front also your going to need head lights
Fri Dec 18, 2015 1:00 am
Tank cover interchange?
Fri Dec 18, 2015 1:07 am
didn't check that, it dam better fit, I will test it tomorrow and let you know
Fri Dec 18, 2015 3:47 am
yea all fits just fine. It seems the only differences are the front for the lights and the look of the side grilles.
Fri Dec 18, 2015 4:44 pm
Ok thanks!
Fri Dec 18, 2015 5:33 pm
Isnt the position of the seat lock different on the left tail section?
If i remember correctly the gen 1 is pointing out to the side and the gen 2 is pointing to the ground.
May be an easy fix tho, not for sure..
Patrick
Future: Unknown
Past:
2012 Green SE ZX-14R - Totaled on 03/28/2013 (caused by a 19 year old driver)
2009 Green ZX-14 - Sold
2007 Blue ZX-14 - Sold
2008 KFX 450R - Sold
2006 Silver ZZR600 - Totaled on 10-31-2007 (caused by a 17 year old driver)
Wed Jan 06, 2016 5:25 pm
Patrick
The key tumbler is in a different place true, but it actuates the actual pin lock seat latch, via cables. The cables might be of different lengths from gen 1 to 2, but I am sure that can be swapped out as needed without much fuss.
Wed Jan 06, 2016 7:10 pm
Well now that I'm about 90% done with this swap.. the overflow tank is different and must be swapped, as well are the upper mounting brackets for the side fairings that bolt to the frame and the brackets on the head fairing stay that the dash panels bolt too and different as well... I got a gen2 trunk lock set and upper tree with ignition and that trunk lock must be changed too
Fri Jan 15, 2016 4:34 pm
So doable, but plenty of details need to be sorted. Post pics if you get a chance.
Fri Jan 15, 2016 4:44 pm
Not completely done with it but almost there
Fri Jan 15, 2016 7:02 pm
Edit: https://youtu.be/5xDumH066k4
[youtube]5xDumH066k4[/youtube]
logged the swapout
Tue Dec 05, 2017 1:39 am
I'd love to see it but the link brings me to my own video manager on youtube.
Tue Dec 05, 2017 5:58 am
Searched YT for his username and found this.
Wed Dec 06, 2017 4:34 pm
thanks, motocycho. And Thanks alexlexus for making the helpful video. :thanks:
Wed Dec 06, 2017 5:08 pm
fixed it check the link again
Wed Dec 06, 2017 11:19 pm
i log most of my zx14 work on my channel. hope anything i do on there helps.
Wed Dec 06, 2017 11:27 pm
https://youtu.be/9f6Ts3KP9y0
[youtube]9f6Ts3KP9y0[/youtube]
fairings all done
Mon Dec 25, 2017 12:58 am
Looks cool, alex!
Mon Dec 25, 2017 7:47 pm
Tue Dec 26, 2017 1:52 am
Users browsing this forum: No registered users and 10 guests
