View unanswered posts | View active topics It is currently Wed Feb 21, 2018 12:01 pm
Reply to topic  [ 6 posts ]
 2012 Front sprocket nut removal?
I'm trying to remove the front sprocket and can't loosen the nut. I bent the locking tab back and with my wife standing on the brakes and a 20" breaker bar I still can't free the nut. I don't have access to a compressor at home. Am I missing something or can I try a little heat on the nut? Last thing I want to do is damage something. Help if you can, thanks, Rick B.
Sat Nov 28, 2015 2:48 pm
Good luck you need A good size compressor to get off
That nut is on tight as heck
Can't figure out why Kawasaki would put on so tight
Sat Nov 28, 2015 4:26 pm
Don't damage the seal getting it hot.
Sat Nov 28, 2015 4:27 pm
It's not so much the compressor as the rattle gun, I needed to borrow a 3/4" high torque gun the first time. It will never go back on that tight I can assure you. Book says 97.3 ftlb but I doubt mine is that tight.
Sat Nov 28, 2015 5:20 pm
The way the nut is made kind of locks itself in place and it takes a real shock with a good air gun to get it to release .. The problem is the trans shaft moves soaking up the hit of the impact gun , Even at 90 foot pounds of TQ it's hard to get off .. I have to turn my regulator on my compressor to 150 PSI and add a few drops of oil to my air gun to spin them off .. :shock:
Sat Nov 28, 2015 5:32 pm
Thanks to all for the reply's. I've got access to an electric impact which I'll try on Monday. If I try any heat it won't be much, worse case I'll load it into the van to take down to the shop and hit it with my good impact. I saw the torque spec. which got me concerned when I couldn't budge it. Read the manual just to make sure it wasn't left handed thread aka old Mopars!
Sat Nov 28, 2015 6:10 pm
Users browsing this forum: fordtech58 and 15 guests
