View unanswered posts | View active topics It is currently Fri Jan 19, 2018 12:41 am
Reply to topic  [ 6 posts ]
 2012 zx14r Problem no speed KTRC and Check engine on
I just put my bike back together after it went down. And bike runs fine actually rode it for about 100 miles. I just cant figure out why KTRC and Check engine lights are on, also the power and traction levels are blank, and I have no speed reading. The bike wont rev past 10k also.
Has anyone ever encountered this issue before. Could it be my speed sensor (the only thing i changed was the front forks so I dont believe its the back 2), could it be the tip over sensor.
Help a brother out.
Mon Nov 09, 2015 12:51 pm
I never had that problem myself ..Seeing the bike has been down I would work in the area that were damaged first.. Check the front speed sensor and the tip over switch first ..I would also unhook the battery for a little time and then hook it back up and see if it clears the problem .. Did it ever pop any codes while riding ?
Mon Nov 09, 2015 2:35 pm
No codes, mostly because im guessing the bike thinks its sitting still. Ill have to get to the bottom of it once it stops raining. it actually starts off with a clear dash where everything seems normal but as I ride it about 2 miles the power and traction go full/blank and lights come on.
Mon Nov 09, 2015 3:08 pm
anybody else know what this could be? or had a similar problem
Tue Nov 10, 2015 11:24 am
I would suggest that if the ktrc is acting up or not working, then the bike isn't seeing an input from the front or rear wheel sensor. It was mentioned that there was work performed on the front, so start there. Either the sensor is bad, the tone wheel is spaced improperly, or bent; or the wiring to the sensor is damaged. Start there and I'm sure you'll find it.
Wed Nov 11, 2015 12:58 am
i had similar issue when i put on the front wheel backwards meaning the ring sensor was on the other side. my check engine light was on and thr ktrc would flash along with the power level.
so i would check the speed sensors front and rear and also check the comnections for the sensors
Tue Nov 17, 2015 9:01 pm
Users browsing this forum: No registered users and 12 guests
