View unanswered posts | View active topics It is currently Tue Jun 27, 2017 2:15 pm
Reply to topic  [ 11 posts ]
 ZX14 turbo billet fuel pump delete plate question
Does any of the turbo guys use a billet fuel pump delete plate? if so do you just unplug the pump and low fuel connetions? and will the fuel guage still work? or will I have a problem? thanx!
Thu Oct 29, 2015 3:08 pm
I made my own, just a plate with 2 holes in it for feed and return, if you do make one be aware the 5 (I think it's 5) mounting holes are not equally spaced, not sure if the fuel gauge ever worked as I only ever run 2-3 liters at a time. I see no reason it wouldn't work.
Thu Oct 29, 2015 3:49 pm
we modify the factory sump on our 14 and busa kits. just need a bulkhead fitting and get rid of the pump. the fuel gauge will work the same this way.
01 ZX-12R 8.84 @ 156.3 no bars, DOT rubber, Pump Gas NA..... turbo 8.47 @ 164
00 ZX-12R 8.62 @ 165.2 no bars, slicks, Pump Gas, 55 shot... turbo 8.32 @173
00 ZX-12R 1: 222.046 1.5: 226.390 Loring AFB Worlds Fastest NA Kawasaki
00 ZX-12R street stealth turbo 1: 227.9 1.5: 234.1 Loring AFB
00 ZX-12R LSR turbo 1: 249.5 1.5: 266.5 Loring AFB Worlds fastest ZX-12R
RCC Turbos & Color Me Gone Racing
Thu Oct 29, 2015 7:39 pm
Thanx for the replies, Scott I have that setttup when I had my street kit,but I have upgraded to a prostreet kit and the return is to small,the stock plate has no room for the 6-an bulkhead for return. I made a plate like Maxx did but don't know what to do about the wiring for the pump and sensor.By the way guys this is my gen1.
Fri Oct 30, 2015 8:46 am
I use the billet plate with outlet and return on a gen 1. You will have to install a 1k ohm resistor in the "low fuel" sensor circuit or your gas gauge will always flash "low fuel".
Best 60foot: ROFL!
Best 1/4mi: ROFLMAO!
Fri Oct 30, 2015 7:10 pm
Kjockey you have a pm.
Sat Oct 31, 2015 7:44 am
So do you....
Best 60foot: ROFL!
Sat Oct 31, 2015 9:21 am
Thanx for the info :bigthumb:
Sat Oct 31, 2015 11:54 am
on a gen 2 the low fuel sensor is not on the tank plate. the float for low level is the small plate bolted underneath the gas tank..
Sat Oct 31, 2015 10:32 pm
I've got this one left from a muzzy fuel pump kit I had
Wed Nov 11, 2015 7:24 pm
My original plate was stainless steel, I need to change the layout so made a new plate from 6061 ally, after only a few days the methanol had started to etch it. Made another from food grade plastic, real lite and the meth has zero impact on it
Thu Nov 12, 2015 2:34 am
Users browsing this forum: Google [Bot], Ty_ty13 and 6 guests
