View unanswered posts | View active topics It is currently Mon Feb 19, 2018 12:47 am
Reply to topic  [ 2 posts ]
 Pazzo clutch perch creaking and sticking
I put a set of Pazzo levers on the bike last year and 3 days ago the clutch lever started acting up on me. The issue is when releasing the lever slowly, it creaks and sticks causing issues at launch or in traffic. The main retainer pin and perch contacts have always been greased. If you look in the perch where the clutch plunger sits, there is a small steel coupling that has a retainer pin and c-clip that holds it inside the perch, that houses the plunger when you pull in the lever. For some reason it has prematurely worn and is the cause of the problem. I put a small amount of grease inside that housing and it didnt help. Have you seen this problem? Any easy fixes other than replacing the entire perch?
https://www.youtube.com/watch?v=9r1ZQRRjZPk
Tue Oct 20, 2015 8:27 pm
Contact Pazzo, they will probably give you a new one, some of the aftermarket levers do this after time
Wed Oct 21, 2015 11:00 am
Users browsing this forum: Google [Bot] and 10 guests
