View unanswered posts | View active topics It is currently Tue Feb 20, 2018 6:16 am
Reply to topic  [ 7 posts ]
 - Converting To ABS? -
Since I have retired my 2012 from racing, I am considering converting it to ABS, for street use. Can anyone tell me the parts I would need? Racheal has an ABS bike, and the brakes feel fine to me.
It may not be worth the trouble/expense...but I'd like to know what it takes. Thanks.
Thu Oct 08, 2015 4:53 pm
I have the speigler lines on my 2015, was like a 2.5+ hour Job. Regarding what parts you need I am not sure but there have to be some differences due to where lines run... You might have fitment issues going to ABS. Check the following thread out, there are some pics.
http://zx14ninjaforum.com/messages.cfm?threadid=F8CF9121-E6EE-3243-FD1F576CA35E32B4
2015 30th Anniversary Edition 14R #250-> Brock's CT Ceramic Coated, PCV w/Ivan's Map, Ivan's ECU Flash V2, Block off plates, WB2 w/lcd, HM Strain gauge quickshifter, GPR Damper, Spiegler lines, Muzzy's Sliders, Pazzo levers, Rizoma Next Fluid Tanks, DDM Ultra 5500K HID's Low & Hi, DB Windscreen, Cox Radiator guard, gold titanium bolts... too many to list at this point
Thu Oct 08, 2015 9:28 pm
Earlier this year, a guy at the other forum converted his NON ABS bike into ABS.
Thu Oct 08, 2015 11:50 pm
I just stripped it all out of my bike, There is a lot of parts.
Brake lines go to ABS control then back to brakes, front goes up under tank then back again.
There is a LOT of wiring, wheel speed sensors, ABS module which goes in behind the Battery so if your using that space for something else your in trouble.
ECU but I do not know what setup.
I have it on my street bike which was also my race bike, I can never remember feeling it activate
Fri Oct 09, 2015 2:49 am
Picture is a thousand words. I will post what I have.
Fri Oct 09, 2015 7:29 am
I thought I had more pics, but this appears to be all of them. Hope this helps in some way.
Fri Oct 09, 2015 7:35 am
Thanks for the input, guys. I think it is a little more work than I want to get into!
Thu Oct 15, 2015 4:06 pm
Users browsing this forum: No registered users and 10 guests
