View unanswered posts | View active topics It is currently Tue Feb 20, 2018 12:48 am
Reply to topic  [ 17 posts ]
 First service time. What oil to use
Hi all
it is come time to get my zx14r its first service. I would like to stick with mineral oil for this service and change to semi-synthetic at 6000ks (2nd service).
Do you guys recommend this?
Reason for this is my Super Blackbird was put on fully synthetic at first service and it started to vibrate after that.
I was thinking of putting Motul oil in. Any other suggestions?
Sun Feb 02, 2014 7:57 am
I personally would do the first oil change with regular oil, and would have done it long before 6k, my reason would be to flush out that factory oil, after 200 miles do another oil change to the synthetic oil of your choice, Motul is great oil. I also would recommend doing this yourself, if you think you can't www.zx1441r.com can lead you through every step, you will know the service was done and know it was done right.. :bigthumb:
Sun Feb 02, 2014 8:32 am
This is the first service the 1000klm one.
going to get dealer to do the services while bike is under warranty, however I will supply the oil if they don't use what I want in bike.
Cheers
Nigel
Sun Feb 02, 2014 9:40 am
Changed mine at 200, 1000,3500. Oil is one of those things everyone has different feelings on. Spectro, Mobil, Royal Purple are my favorites for no other reason than I have used them all for years and none of them hves ever let me down.
2015 30th Anniversary Edition 14R #250-> Brock's CT Ceramic Coated, PCV w/Ivan's Map, Ivan's ECU Flash V2, Block off plates, WB2 w/lcd, HM Strain gauge quickshifter, GPR Damper, Spiegler lines, Muzzy's Sliders, Pazzo levers, Rizoma Next Fluid Tanks, DDM Ultra 5500K HID's Low & Hi, DB Windscreen, Cox Radiator guard, gold titanium bolts... too many to list at this point
Sun Feb 02, 2014 11:38 am
Cheers
Nigel
Not telling you what to do, but if the dealer is charging you a lot, you can do the oil change yourself even when it's under warranty, I just used the kawasaki oil filter, as for oil, if you do let the dealer do it, the regular dino kawasaki oil is fine , other oils to use for first change is rotella dino oil, I changed mine at 100 miles and just used some castrol 10/40 dino motorcycle oil because I had some laying around, then at 600 and until around 3300 I used rotella dino, then after 3300 went to Motul 7100 full synthetic, I wouldnt be in any hurry to go full synthetic on a street bike though, just change the oil a little sooner if you use dino oil instead of synthetic.
Finally, you CAN use any NON- energy conserving car oil that is in your weight range, hope this helps
Sun Feb 02, 2014 12:57 pm
I've been using Allison oil from Brock's since the first oil change on the 14. Makes power. Lasts long. Protects well. I put in the recommended Petron additive from them as well at every oil change.
2009 Black and CF ZX14 2005 Turbo Hayabusa 2001 GSXR 1000
Looking for another turbo ZX14 or 84-85 GS1150E.
Sun Feb 02, 2014 4:42 pm
I've been using the Alysin oil as well since new but it is a oil that requires frequent changes, no more thank 3k miles which is what i do anyways.
I have been sending my oil to get analyzed and i'm working on mixing some different types of oils to get the ZDDP levels a bit higher, my first and current test is with 2 quarts of mobil 1 10w-40 and the rest with the Alysin 0w-20 i'll be sending out the oil analysis soon as i get close to 3k and see what it comes up with.
Here is an article sportbikerider did on different types of oils and has alot of useful information, make sure you read both parts.
http://www.sportrider.com/tech/146_0308_oil/
Gully Blue 2012 ZX14R
Stock Gearing/Guhls Brocks V2 ECU Flash/PCV w/custom map/Blue CT meg exhaust/flies out/Alysin <0 synthetic oil
Mon Feb 03, 2014 8:24 pm
100 miles and dump the crap oil ... Go full syn oil ... Never look back ... :thanks:
Mon Feb 03, 2014 8:27 pm
I asked the dealer and they said they use Motul 3000 which is a mineral oil and then change to synthetic after 6000klms
Sat Feb 08, 2014 6:10 am
Sounds good
Sat Feb 08, 2014 7:26 am
If you experience ANY downshifting problems especially 3rd to 2nd and 2nd to 1st go to any good FULL synthetic. Dealer here in Indy says of Mobile 1 synthetic if even 1%of the content is synthetic it can be called such.Try any listed above. Have had zero down shifting errors since changed to full synthetic. However, a local dealer/25 year drag racer of both Busa and Kawasaki says the is a small problem with the current zx14r shifting petals design causing a bit of a downshifting error from 2nd to 1st. Full synthetic solved my ONLY irritating zx14r problem in 17000 miles.
Moo gator
Mon Aug 03, 2015 11:11 am
Moo gator
I've owned 2 zx14-r's since 2012 and have never had 1 problem downshifting from 2nd to 1st, or any other gear for that matter. Your dealer says it's the "design" causing the problem then how does oil solve the design of the petals problem?
Mon Aug 03, 2015 11:28 am
First oil change on my 30t, 800 miles then went to Brad Pen 10w40.
Mon Aug 03, 2015 12:00 pm
Wee
Problem downshifting with synthetic better but still hangs up if shifting "quickl"from 3rd to 2nd and 2nd to first. This may not be typical but was a consistent problem before going full synthetic on my bike. I have tried downshifting agressivly and quickly as stated and sometimes hangs up sometime not.
Moo gator
Tue Sep 15, 2015 7:19 am
Wee
Thanks for the input. Bike seems to be shifting more consistently as miles accumulate. At 17500 it seems to have fewer hang ups when down shifting in the lower gears. I am not the racer type that seems to pervade this site and may need to further adjust my techniques. I have been riding for 50 odd years and this is the only bike that has a downshifting issue. I swear by all things Holy that dat bitch would aways hang up from 2nd to first if shifted quickly. Full synthetic has solved about 95% of the errors not perfect as stated in past blogs.
Again wee.Thanks as always for your Input. Why is it my remarks in particular seem to catch your eye? You are very analytical. Nice to get your feedback.
Moo gator
N
Tue Sep 15, 2015 7:37 am
alligatorz
Quick shifting question since the preceding posts covered the oil part. Do you match rev's (blip the throttle) on your downshifts? I ask because I always do and have no downshift issues in 41K miles using Mobil 1 motorcycle 10w-40. Just curious. Good luck.
Wed Nov 18, 2015 1:29 am
I would stick with Kawasaki 10-40 oil until next service and then go synthetic. I'm a big fan of Amsoil.
Thu Nov 19, 2015 1:32 pm
Users browsing this forum: No registered users and 18 guests
