View unanswered posts | View active topics It is currently Tue Feb 20, 2018 6:11 am
Reply to topic  [ 5 posts ]
 mods?
Things I'm looking for are exhaust with at least cat delete and an air filter I have not found either online. Any help is appreciated. I think the only other thing that will be needed is a guhl tune which is local to me. Any thoughts?
Sun Jun 14, 2015 5:44 am
I've only seen end cans so far. A few fabrications have been done, one-offs but nothing on the market yet. I'm sure this situation will change though.
I know when I first spoke to Brock, soon after the H2 launch, he said he had nothing at that time. A few months later and he's up to speed with a few different cans and other stuff, I knew he would be, so keep looking and the products will appear, probably sooner than we think.
Sun Jun 14, 2015 11:12 am
I am looking for a front sprocket. I can only find a 19 tooth. I am looking for a 17 and a 16; does anyone know what sprocket from any other bike that will fit this monster?
Justoyz Racing
2012 ZX14R-Blk/BST/Aumni Pro/BST/Brock
2012 ZX14R Candy Red-Blk/PM-wheels/Evil/Brock
2014 Zx14R Fire Red/PM-wheels/Orient Turbo Kit
ECU Flashing
808-542-2496
Sun Mar 20, 2016 3:15 am
I believe the spline is the same as the ZX-14 (easy to verify), but there is a slight difference in offset? So, you should be able to modify a 14 part to suit your needs.
Sun Mar 20, 2016 12:06 pm
The spline is the same as the ZX14, however, the problems that you run into is the offset isn't the same. Your chain will not be in line like it should be. Also, I don't believe that anyone is making a 525 ZX14 front sprocket or a 530 rear H2 sprocket.
Fri Mar 25, 2016 8:00 am
