View unanswered posts | View active topics It is currently Wed Jan 17, 2018 8:57 pm
Reply to topic  [ 2 posts ]
 Trickle Down....
And so it begins.............how far will it go? Can't wait to see....... :thumbs:
https://youtu.be/kHxJL3bD4og
https://youtu.be/GX-o5ry-_5E
https://youtu.be/gaSYYM0gfTE
https://youtu.be/loFwJrU3EA8
Wed Nov 08, 2017 8:56 pm
Sounds Good! For those who don't have time to watch all of them, the last vid states some of the following.....
197 HP @ 11K rpm
101 lb/tq @ 9.5K rpm
traction control
wheelie control
electronic cruise control
less aggressive ergos than a 14R
SE edition available with
launch control
dual direction quick shifter
cornering lights
I didn't hear weight.
**edit**
She needs to lose about 75lbs.
Unashamedly stolen from here.
http://www.bikeland.org/board/viewthrea ... 1510112130
Specs:
Engine
Engine type: Liquid-cooled, 4-stroke In-Line Four with Supercharger
Compression ratio: 11.2:1
Valve system: DOHC, 16 valves
Bore x stroke: 76.0 x 55.0 mm
Displacement: 998 cm³
Fuel system: Fuel injection: Ø 40 mm x 4 with dual injection
Starting System: Electric
Lubrication: Forced lubrication, wet sump with oil cooler
Performance & Transmission
Maximum torque 101lbft / 9,500 rpm
Maximum power 197HP / 11,000 rpm
Transmission: 6-speed, return, dog-ring
Clutch: Wet multi-disc, manual
Primary Reduction Ratio: 1.551 (76/49)
Gear Ratios: 1st 3.077 (40/13)
Gear Ratios: 2nd 2.471 (42/17)
Gear Ratios: 3rd 2.045 (45/22)
Gear Ratios: 4th 1.727 (38/22)
Gear Ratios: 5th 1.524 (32/21)
Gear Ratios: 6th 1.348 (31/23)
Brakes & Suspension
Brakes, front: Dual semi-floating 320 mm discs. Caliper: Dual radial-mount, monobloc, opposed 4-piston
Brakes, rear: Single 250 mm disc. Caliper: 2-piston
Suspension, front: 43 mm inverted fork with rebound and compression damping, spring preload adjustability and top-out springs
Suspension, rear: New Uni-Trak, gas-charged shock with piggyback reservoir, compression damping, rebound damping, remote spring preload adjustability and top-out spring
Frame & Dimensions
Frame type: Trellis, high-tensile steel with Swingarm Mounting Plate
Trail: 103 mm
Wheel travel front: 120 mm
Wheel travel rear: 139 mm
Tyre, front: 120/70ZR17M/C (58W)
Tyre, rear: 200/55ZR17M/C (75W)
L x W x H: 2,135 x 775 x 1,205 mm
Wheelbase: 1,480 mm
Ground clearance: 130 mm
Fuel capacity: 19 litres
Seat height: 835 mm
Curb mass: 564 lb
Fri Nov 10, 2017 10:32 am
