View unanswered posts | View active topics It is currently Mon Feb 19, 2018 2:50 am
Reply to topic  [ 3 posts ]
 brocks clutch mod for 2012-2013 zx14
I just installed the brocks clutch mod on my 2012 zx14, very simle install, but when i started the bike on the rear stand pulled the clutch in and put it into gear the rear wheel was spinning very fast and I couldn't stop it with my foot, is this normal when removing the slipper clutch, or is it normal, I thought it would work the same way, when the bike is in gear with the clutch pulled in that the rear wheel would spin a little and you can stop it, brocks doesn't have and answer for me yet, Should I try to take the bike off the rear stand and try it that way to see if the bike pull's foward with the clutch pulled in, need answer's before I put the clutch cover back on, I had it apart 3 times and everything is installed correctly,thanks,mike
Thu Mar 19, 2015 11:50 am
What shims did you use ?
Thu Mar 19, 2015 2:21 pm
Take it apart and make sure everything is where it should be according to the instructions.
Thu Mar 19, 2015 2:24 pm
Users browsing this forum: No registered users and 3 guests
