View unanswered posts | View active topics It is currently Fri Dec 15, 2017 10:39 pm
Reply to topic  [ 5 posts ]
 2014 ZX-10R Tuning Day
Thought I would share this fun dyno session!
Beautiful White Zx-10R, cat delete pipe, 182+ hp / 80ft. Lbs. when all was said and done. Beautiful machine and well sorted, straight Ecu flash, variable traction control with % slip adjustment in the flash in various modes etc. Really awesome day, lots of fun, learned a bunch about high flow volume! thanks Nels!
:vroom:
http://youtu.be/u7n-BTgZXLs
That's basically Nels checking feel after last flash write and then pulling 5th, then we overlay and compare. We then shut down, discuss variables, if data logging, I will then test pilot and hit targets Nels asks for in rpm range and gear. Then we check data, adjust trims if necessary, and re-check on dyno for a 'sheet pull'.
14 Nation
Disciple of The Way of The 14R
Vincit Qui Patitur
Wed Nov 05, 2014 9:06 pm
:thumbs:
2013 ZX-14R SE
Zero Gravity double bubble wind screen
Cblast flash
Muzzy black stainless Slips
Yoshimura fender delete
Custom machined bar risers by Me
Wed Nov 05, 2014 9:28 pm
:thumbs: :bow:
Wed Nov 05, 2014 9:29 pm
YOU sound like your HAPPY!!
:thumbs:
2004 zx12 1290cc 191std HP 495 lbs
2014 zx14r 195sae HP 520 lbs
2014 Loring AFB 14 runs over 200mph
with a best of 208.1 in 1.5 miles
and 204.5 in the mile.
Mon Feb 01, 2016 9:58 pm
:thumbs:
Why did this 15 month old thread get revived?
Wed Feb 03, 2016 12:03 am
