View unanswered posts | View active topics It is currently Wed Feb 21, 2018 2:05 pm
Reply to topic  [ 3 posts ]
 05 zx10r clutch problems
hello my problem is when im at dead idle and clutch is engaged, its hard to put in neutral. And while staging the bike still want want to move. On decel the rpm stay up with the clutch engaged until comes to a complete stop. help please!!!!!!! thanks
Mon Feb 24, 2014 10:27 pm
Sound like warped steels to me , or your clutch is flat worn out ..
Mon Feb 24, 2014 11:30 pm
Man, when I had warped steels on my 10, it just didn't want to go into neutral at a light, but that could still be the problem. I think your problem is the engagement rod that goes down into your clutch cover. The groove that meets the pin is very thin. I've gone through a few of them on my 10. Its easy to check. Just take your clutch cable off and turn the rod counter clockwise and pull it out. You will be able to tell if its bad.
Mon Mar 09, 2015 12:09 pm
