View unanswered posts | View active topics It is currently Mon Feb 19, 2018 3:06 am
Reply to topic  [ 5 posts ]
 rebuilding ZX12R clutch for dragstrip (need suggestions)
Lee Pritchard and I are rebuilding my clutch on my 2000 A1ZX12R. It already has the muzzy muzzy clutch kit w/ hub, 3 stiffer springs, muzzy steels and fiber. I also have the falicon billet basket.
I went to the track and spent my clutch. Not horrible, but if you spin it over 9000 rpms it will slip. I heard Rick has a good set up for the track. Does anybody have any suggestions. Lee knows his way around bikes like a doctor, he's just never worked on the ZX12's.
Thank u for any advice.
Thu Nov 14, 2013 10:23 pm
Just run good OEM steels and fibers. Triple check stack height. 13 years old may as well get a new clutch cable. I imagine you are stretched so I can't help you there on setup. Stock motor/wb 3 springs stock 3 stiff is perfect.
DO NOT SKIMP ON THE BILLET CLUTCH BASKET. GET IT CUZ ONCE YOU RUN 1.6 60 FTS I CAN TELL YOU WHAT HAPPENS :fishslap:
Gemini Motorcycles
Fastest I've gone on....
ZX-14R -- 205 mph
ZX-14 on spray -- 222 mph
Fri Nov 15, 2013 10:40 am
I already had one made from Falicon. Dam it is pretty.
Fri Nov 15, 2013 2:20 pm
What did they charge ya?
Gemini Motorcycles
ZX-14R -- 205 mph
Fri Nov 15, 2013 3:58 pm
i havent bought fibers in a few yrs, but i go through some steels. been having better luck with cycle concepts steels. next time i do buy fibers i will try their drag pack
01 ZX-12R 8.84 @ 156.3 no bars, DOT rubber, Pump Gas NA..... turbo 8.47 @ 164
00 ZX-12R 8.62 @ 165.2 no bars, slicks, Pump Gas, 55 shot... turbo 8.32 @173
00 ZX-12R 1: 222.046 1.5: 226.390 Loring AFB Worlds Fastest NA Kawasaki
00 ZX-12R street stealth turbo 1: 227.9 1.5: 234.1 Loring AFB
00 ZX-12R LSR turbo 1: 263.1 1.5: 266.5 Loring AFB Worlds fastest ZX-12R
RCC Turbos & Color Me Gone Racing
Tue Nov 26, 2013 10:21 pm
Users browsing this forum: No registered users and 3 guests
