View unanswered posts | View active topics It is currently Fri Dec 15, 2017 10:38 pm
Reply to topic  [ 1 post ]
 Leakdown Tester
The APE / Racetoolz dual gauge leakdown tester is easy to use, and can help pin point internal engine damage. Fit it into spark plug hole and connect it to an air supply. The dual gauges will tell you the percentage of leakdown, if any.
Used by top engine builders.
Available with, 10mm, 12mm, or 14 mm spark plug hose.
These leakdown testers are build in the APE shop and are very accurate.
Racetoolz.com is the special tool division of APE. Check it out.
http://racetoolz.com/
Speed Merchant
The ZX Zone
Crankshafts
Cylinder heads
Trac King Clutches
Tue Aug 18, 2015 12:57 am
Users browsing this forum: No registered users and 2 guests
